Continue riveting front and rear spars. Going pretty well. Using little longer rivets than plan calls out for. Talked to tech support and they said that even though the rivet gauge says they are a little small, use them anyway. It has all been factored in. Rivets slightly small will still be stronger than rivets a little longer that have a tendency to bend over. Maybe that is why the pneumatic squeezer was having trouble with the rivets that were a little long. That had to be squeezed just a tiny bit too much and the range of the squeezer is very limited.
