Rob's REBVAIR Project
Date:  5-22-2015
Number of Hours:  4.00
Brief Description:  Mixture control cable routing
This was exceedingly challenging as I had to gave priority to the routing of the throttle cable, and in so doing, precluded the mixture cable entering directly from the side of the carb. I had to have the mixture cable come in slightly from the front to avoid interference with the open and closed throttle arm positions (Image 1). However, once the geometry was worked out, the configuration allowed a nice curvature (loop) of the cable as it exited the firewall (Image 2).
The rebel panel really seems challenging in getting the cables to their desired locations since all controls terminate under the engine, and there simply isn't a lot of space for the cable housings to make the required S-bends.
I sure hopethese pictures helps someone out there, because I certainly struggled with getting this all worked out.
cable routing at carb
looping cable from firewall
