Rob's REBVAIR Project
Date:  9-19-2020
Brief Description:  Brake line bleeding
I fabricated a brake fluid reservoir from 3" PVC pipe (image 1) that allows me to fill the lines from the lowest point (brake caliber assembly). Transmission fluid was used (not car brake fluid) and the system pressurized at about 25 psi from the compressor.
homebuilt reservoir
homebuilt reservoir
brake fluid reservoir on firewall
