Rob's REBVAIR Project
REBVAIR
gear install
3-25-2018
Brake line install : part 2
Inside, a 2' hose leads to the left brake cylinder, terminating in another 90 degree AN4 to 1/8" fitting (image 1)
On the other side, a 40" hose connects the right-hand cylinder to the bulkhead fitting (image 2)
I used the MAM-supplied polyethylene tubing for the low-pressure connections back to the reservoir (image 3).
left 2' hose
right 40' hose
Master Cylinder tubing
REBVAIR Home
1774
control surfaces
controls
Cowling
elevator install
engine accessories
365
450
gear install
General
Instrument Panel
48
217
paint
Panel
Parachute
Wing
wing install
