Rob's REBVAIR Project
Date:  9-23-2009
Number of Hours:  5.00
Manual Reference:  Chapter 12
Brief Description:  Riveting roof skin and corner wraps
I needed to free up some clecos to continue with the floor channel install. Also, I needed a bit of a sense of accomplishment that only riveting can bring! I cleaned and scotch-brite sanded the mating surfaces, mixed up some epoxy primer, and riveted most of the roof skin and top corner wraps to the structure. I left the actual corners clecoes, as other builders have recommended this area stay "open"until the fairing boxes are installed (only after the wings are installed). It was all very gratifying!
right side
right side
left
left
