Rob's REBVAIR Project
Date:  10-5-2016
Brief Description:  Windshield Install Part 7: install sequence part 2
Continuing from part 1:
Step 10) cleco retainer into place and take a break.
Step 11) Starting at the top retainer, start forcing the retainer into contact with the fuselage before setting rivets. I used some wing-nut clecos that really cinch things down. Move to sides next, then front retainer.
Step 12) Make sure nothing is extruding onto the windshield itself. Clean with 'Prist" cleaner.
Step 13) let it all sit for 1 or 2 warm days before trimming extruded butyl tape or glazing compound. Then trim with a plastic knife and remove the painter's tape.
Stand back, admire your handiwork, and move on to the next task.
wing-nut clecos to cinch retainer down
side retainer
side retainer
removing tape on front retainer
