Brief Description: Riveting roof skin and corner wraps
I needed to free up some clecos to continue with the floor channel install. Also, I needed a bit of a sense of accomplishment that only riveting can bring! I cleaned and scotch-brite sanded the mating surfaces, mixed up some epoxy primer, and riveted most of the roof skin and top corner wraps to the structure. I left the actual corners clecoes, as other builders have recommended this area stay "open"until the fairing boxes are installed (only after the wings are installed). It was all very gratifying!
