Rob's REBVAIR Project
Date:  7-26-2020
Number of Hours:  1.00
Brief Description:  Air vent inlet Part 2
Image 1 shows the fairing with the vent rivetted in. I used RTV to seal the gaps between the inlet and the fairing to prevent losses. Image 2 shows how the NACA inlet gets connected to the 1" hose adapter on the fuselage with flexible black SCAT tubing. The sharp turn in the tubing will obviously further reduce the velocity of the incoming air, but again, lets see what we get at 60 knots (and up). Image 3 gives a better perspective of the angle of the inlet v. relative wind. I am hopeful that I'll be pleasantly surprised, and again, an exterior scoop can always be added later.
NACA inlet revetted onto fairing
SCAT tubing connection
will it work?
will it work?
