Rob's REBVAIR Project
Date:  3-13-2019
Brief Description:  Sight gauge fuel bung install
Also added two additional fuel port bungs to the wings to provide better sight gauge readings. Was relatively simple to drill the holes and prep the surface for final install with the fuel sealant.
Images are of each wing, at different stages of completion: Image one is right wing before final install. Image 2 is left wing after final install.
Bung clecoed in place and surface prepped
installed with the 2-part fuel sealant
