Rob's REBVAIR Project
Date:  3-11-2019
Brief Description:  Aileron install
Installed the ailerons today. Wasn't as hard as I envisioned feeding the bolts through the holes and tightening the nuts. It's really just the center connection bolt that presents the challenge.
Two areas on each wing where the aft wing skin needs to be bent up a bit, but otherwise ready to rig with the internal torque tubes.
Also connected the control horns on the torque tubes, facilitated by the fact that I had already cut and fitted all the components several years ago.
ailerons installed
ailerons installed
control horns torque tube connected
