Brief Description: Remote magnetometer and OAT wiring
Using a Switchcraft 5-pin weatherproof connector allows easy and simultaneous disconnection of both the remote magnetometer and the Outside Air Temperature probe. Again, all this is to make it easy to remove or service the wings without having to pull wiring.
When looking at the connector head on (with the keyed indentation on the top as pictured): the top two pins on either side of the key are OAT wires GND (left) and signal (right). The lower three pins are for the Magnetometer (from left to right);Brown/White (RS232); Red/White (PWR), and Black (GND).
The wires leading to the OAT probe are grey and black. The black wire Black is connected to GND.
