Rob's REBVAIR Project
Date:  9-17-2017
Number of Hours:  10.00
Brief Description:  Fuel system design and installl (part 1)
The sight gauge itself if modeled after an idea circulated on our builder's list. Some clever use of aluminum tubing and tight-fitting tygon tubing and nipple fittings makes for a sturdy sight gauge. (See link https://www.murphybuilders.net/download/file.php?id=2211)
The NPT fittings here (and elsewhere) are beingused as bulkhead fittings by virtue of the unused threaded portions. Image 2 shoes this best: I added the correct number of aluminum washers so that the NPT fitting was snug to the outside feul fitting, while simultaneously sandwiching the wing-root bulkhead. Very secure and lightweight. The nipple fittings are inserted into the tygon tubing with a 'proseal-like' 2-part compound from aircraft spruce (recommended in the link I provide above). The pro-seal not only improves the seal, but acts as an adhesive that greatly solidifies the nipple fitting connection. On a test sample, I was unable to pull the fitting out of the tubing even after exerting 20-30 lbs of force. With the fittings firmly attached to the bulkheads, these joints will never even see such loads.
sight gauge
sight gauge
NPT fitting through cabin
sight gauge lower connection
