Rob's REBVAIR Project
Date:  2-4-2017
Number of Hours:  4.00
Brief Description:  Rudder tip install
Finally completed the installation fo the rudder fiberglass tip. This being my 3rd one, it was an uneventful install. The only difference here was that I decided to forego the machine screws in attaching the ST-40 bracket to the outboard rudder rib, opting for rivets instead (as I alluded to in previous posts). For final install, the metal 'skeleton' will first be rivetted to the rudder through the ST-40 bracket (Image 2). Then the tip will slid onto the structure and riveted in place (Image 3). Again as I note in other posts, to reverse the install, every single rivet (35/35) would need to be removed from the tip before sliding it back off it's metal 'frame'. If I had used screws on the ST-40, only the rivets that hold the tip to the rudder would have to come off (20/35) to remove the tip. For the rudder, I just didn't think it was worth the trouble. It's worth noting that the installation of the ST-40 requires a hole to be drilled in the tip (not shown) so the holes can be drilled through the ST-40 into the outboard rudder rib. Again, there's a lot of extra steps and patience required to make this conform to the design, but I'm convinced it will pay off in the long run.
final tip trimmed and clecoed
ST-40 attach to end-rib
sliding tip over frame
