Brief Description: Elevator Trim Part 2: panel wiring
I used D-sub connectors to connect the wires and power, then heat-shrink to stop them from coming apart. Added some spiral wrap for abrasion-resistance (Image 2), and the bundle sits nicely on the 'shelf' behind the panel. All exposed edges of aluminum are getting rubber edging too for belts-and-suspenders abrasion protection. Image 3 shows the Switchcraft connectors I used between fuselage and elevator, and again between elevator and the servo itself (Here it is simply plugged into the fuselage wire for testing purposes). With these connectors, the servo can be serviced without physically cutting wires.
