Ran the RG400 coax cable for the comm radio/antenna and crimped on the BNC connectors. Though relatively simple work, one has to be careful not to cut or nick the insulator, and with two layers of shielding and a utility knife (new blade) it's surprisingly easy to do just that (nick the insulator, that is). Nevertheless, got it done.
Image 1 shows how the antenna cable follows the panel reinforcement tubes to the firewall (see the beige RG400 cable close the firewall). This gets routed up the front post (See glimpse on the right side of Image 2) and then through the fuselage.
l also reinforced the antenna attach plate, as it wobbled a bit too much under simulated forward speed loads (Image 3).
