Brief Description: Coil/gascolator cooling box Part 2
Here's a look at the box from the outside. I wanted to be able to inspect/service the gascolator without too much hassle, so I designed the box cover to be removable by simply sliding out the hinge pins on the aluminum hinges. I cut a recess in the front to clear the engine mount tubes. I might put some 1/8" silicone inserts here to help seal the gap a bit. Not sure how critical it is.
The length of the box on the inboard side helps shield the gascolator (not yet installed) from heat emminating from the exhaust pipe.
The inboard box 'leg' is the full thickness of the box, while the outboart leg is as short as it can be. This is to allow easy access from the outside.
