On the left side baffle, there's a rather large and very asymmetric hole where the stock oil cooler ought to sit. This needs to be covered somehow, and this time Roy suggested a sculpted piece of 0.016"aluminum. After a bit of trimming on the baffle itself, it was relatively easy to achieve the outcome in image 1. Some paint and a little RTV around the edges and it's complete.
The SS tube running right through the patch plate is the 5th bearing oil line. Anyone using the Weseman bearing would not have to deal with this.
