The ignition wires need to enter the baffle pressure 'chamber', and the WW approach is to cut a hole in the rear baffle that is covered with a nylon insert with 6 holes drilled to accept the ignition wires. Easy enough.
Also, that rear baffle was trimmed to clear the distributor body.
Finally, all the silicone baffle material attach holes got drilled.
