Rob's REBVAIR Project
Date:  3-29-2014
Number of Hours:  6.00
Brief Description:  upper cowling panels Part 1
After again cutting a paper template to size and transferring to the stcok 0.025" sheet, and after a lot clecoing, marking, unclecoing, trimming, and clecoing, I had a fairly nice flat panel that fit reasonably well over the top right cowl. To account for the fairly tight 90 turn on the upper firewall, I had to introduce a significant bend in the sheet, so it went around this bendwith ease. Image 1 shows the curvature.
You can also see a couple of elongated holes I made in a sacrificial area at the bottom part of the sheet that overlaps with the lower panel. That's where the straps will go (as in Image 2).
right upper panel curvature
panel closed and cinched
nice lines
nice lines
