Steve's CH750 Cruzer (N750SB)
Date:  2-23-2018
Number of Hours:  1.50
Brief Description:  Finished Pilot Side Access Cover
Had just enough time to work today to finish up the pilot side trailing edge access. Drilled the nutplate rivet holes, deburred, and riveted the nutplates in place. Partially attached the cover with screws then removed the covers again from both sides.
Access cover partially attached
