Brief Description: R Wing (Insp panel, bolt access) Hoist frame
In preparation for initial mounting of the passenger wing I made some changes. Cut an access panel opening in the trailing edge to provide access to the fuel and vent line connections. I will fabricate a backing plane and cover once I have the wing mounting configured. Some builders have had to trim the inboard edges of the wing, so I will wait until I have final dimensions.
Based on the HBH video, I made an opening in the leading edge for getting to the attach bolt. I probably should have waited until mounting the wing to see if this is necessary. I can fabricate a covering if needed.
In preparation for lifting the wings into position, I fabricated a simple lifting frame from 2X4's and plywood.
