So I discovered the beginnings of a crack where the skin makes the radical bend for the nose. No doubt from a bit too many test fittings. I removed the skin,stop drilled the crack, cleaned it up, and essentially relocated the bend point on the skin. This actually made the fit a bit more uniform and I think relieved some stress at that point. When I mount the wings I will probably come up with some sort of backing/fill/moulding to keep airflow from entering and causing vibration.
