Deburred the front spar and skins where not already done after drilling was done a while ago. Installed the Skytek fuel line package. I purchased it and the Skytek header tank after seeing the installation in a Cruzer at Open Hangar Days. The installation instructions on the website are a bit disjointed, but once the hole for the return line is drilled, the rest is pretty intuitive. Used Loctite 567 on the AN fittrings. I will do another leak test before buttoning up the top.
