Steve's CH750 Cruzer (N750SB)
Date:  10-29-2016
Brief Description:  Spar root rib
Positioned root ribs. Expanded spar holes for A6 rivets,Incrementally expanded holes on bottom to #20. Cut and drilled doubler. Riveted ribs to spar with A6 rivets, bottom,rear spar, and doubler with A5. I was going to continue in that area, but could not find the spar root angle. It should have been in my wing box where I had all the wing parts. I'm not satisfied with how the root area turned out on the right wing, so I'm ordering some replacement parts for that area anyways. I could start on the tank, but I'm waiting on a replacement float arm for the sender. Seems like a good time to take a break from work in the wings while stuff is in transit. Then when I have everything I'll finish up both wings.
