Brief Description: Organized - Drilled ribs & Cleco'd to spar
Located and separated Port and Starboard wing skeleton parts. Will start with starboard (passenger) side. Drilled rib flange holes not pre-drilled to size 30 then 20. Cleco'd to spar except for most inboard forward rib. Encountered a bolt pre-installed where front rib hole should be. Not an issue on the rear side due to rib shape. I probably just need to trim out that spot on the rib flange, but will check the forums and/or Roger to be sure.
