Brief Description: Finish securing ADAHRS, secure pilot side wiring u
Fully secured the ADAHRS unit under the pilot seat. I had the forward screws in place, but the rear were difficult to get to. I finally just drilled some holes in the seat base to allow a screwdriver to reach the rear mount points on the floor.
While I was in there, I took the opportunity to secure the wiring and lines that run through there. I affixed loom to the edges of the lightening holes that lines and wire pass through. Silicone sealant in the loom should keep it in place, but be easily removable if needed later.
