Attached the brake line retaining covers. Deburred the covers and riughed up the inside faces and trailing edge of the main springs. Used tape to mark off where the adhesive needs to go. Test fit everything including using bungees to hold the cover in place. Mixed up some JB Weld and smeared it onto the spring only to keep from having it back up and interfeering with the brake lines. Attached the covers and bungeed into place. Removed tape and cleaned up as good as I could. Going to let this cure overnight.
