Steve's CH750 Cruzer (N750SB)
Date:  12-28-2017
Brief Description:  Fabricating brake line passthroughs
Started fabricating a couple of brake line fuselage exit fittings based on the tip from Mark Pensenstadler on his blog at http://www.zenithowner.com/29jan17.htm . I used some aluminum tube from Grainger that is just a touch larger than the quarter inch brake line. The line fits snugly, but does not pinch. The shop is below freezing, so I did the JB Weld later in the house after everything warmed up a bit. I'll give it a couple of days to fully cure before installing.
Ready for JB Weld
Ready for JB Weld
