Brief Description: Installed new firewall components, nose cushion
Deburred, treated and installed the firewall channel, doubler, and stiffener which I had to replace because of my earlier mis-drilling of the lower cushion.
This time when I fitted and drilled the cushion, I made sure everything was positioned and secured properly and double-checked what I was doing. After tapping the block for the mounting holes, everything still fit well. Made a new template for locating the rear hole to match the cushion, and this time it was spot on. Still not sure how I messed it up last time, but this time all went well. The bolts were well aligned. Added washers and nuts. Did not safety wire the lower cushion attach bolts at this time.
Replaced the firewall components from previous mistake on cushion
