Steve's CH750 Cruzer (N750SB)
Date:  5-6-2017
Number of Hours:  0.75
Brief Description:  Drilled nosewheel axle hole
Applied masking tape to gear and marked locations for axle holes. Started with #40 drill bit and gradually upsized until finishing up with a step drill bit to 3/4". This was still a bit snug for the axle, so I ran a sanding spindle around in the hole until the axle would go through. Loosely attached the axle hardware.
Pilot drilling axle holes
Nose gear with axle
Nose gear with axle
