Brief Description: More sanding and smoothing of cowl halves
Did what I hope will be the final sanding of the cowl halves. I know it is not perfect, but it is much better than it was. I used the disc sander, the multi-tool with a sanding pad, and medium and fine grit sanding sponges. Had to slap some additional bondo onto some thin spots.
