Brief Description: Added fuel line brackets in cabin and connected fi
Fabricated a 2nd support bracket (1 done lots earlier) and mounted them on the channel beside the outboard lines which already had channel pass=throughs. Inserted the lines and attached right angle fittings to the short lines extending out the fuselage into the wing trailing edge area.
