Steve's CH750 Cruzer (N750SB)
Date: 9-16-2017
Number of Hours: 7.75
Brief Description: Wiring coming together
Replaced all the temporary wood screws on the avionics shelf with screws, washers, and nylock nuts. In the process, of swapping out the hardware, I sanded the plywood with a belt sander to give it a smoother texture and cleaner appearance. Added busses for avionics power and ground separate from the engine related wiring, but have not connected them yet. Made a cutout in the plywood to accommodate the map box option. The plywood will give me something to secure the box to later. Since the panel folds down, the body of the map box needs to be secured behind the panel rather than to the panel itself, which will only have the map box door. That shelf real estate had been utilized by the ECU, so I'll have to find another location for it and the Viking View box. I haven't yet added stress relief, loom, and final routing, so its kinda like a rats nest right now, but it will get cleaned up later. At the end of the day, I have switches and breakers wired for battery selection, L/R fuel pumps, and partial ignition. Not connecting power cables to the batteries yet.
Pilot side avionics shelf
Center console rats nest
Cutout for map box
