Started to work on the side upholstery that came with the Zenith upholstery kit. Working on the pilot side, I cut openings for lines and such in the foam/aluminum panel for the pilot side. To give it some surface to adhere to on the aft end, I cut some L angles and JB welded them to the frame structure.I'll let them set overnight.
