Steve's CH750 Cruzer (N750SB)
Date:  10-3-2018
Brief Description:  Installed deat belts
Installed the seat belts. For the most part, it was straightforward, with the exception of the upper attach point. It was not easy to get the bolt behind the bracket given the angle. Would have been better to insert the bolt before riveting the bracket in place. The seats came off to get good access to the lower attach points. Moving on to upholstery on the tunnel sides since I'm in that area.
Seat belt
Seat belt
