Steve's CH750 Cruzer (N750SB)
Date:  5-3-2017
Number of Hours:  1.50
Brief Description:  Pilot seat pan
Bolted the pilot side actuator assemblies into place. Drilled and deburred the seat pan using the pre-drilled locations. With the distance between the actuators based on the seat pan pre-drilled holes it did in fact go together better than the passenger side. The pan does slide well when the actuator lever is pulled.
Pilot seat pan temporarily installed
