Brief Description: Riveted seat support angles, Started torque tube b
Riveted the rear seat support angles in place with the passthrough grommetts installed.
Started assembly on the 3 piece front torque tube bearing assembly (bearing, doubler, fairlead). Positioned and drilled the mounting holes and fairlead holes (#20 in fairlead, 1/4" in bearing and doubler) as well as the oversize hole in the fairlead for the torque tube.
Started to position the torque tube and discovered the end cap was powder coated onto the torque tube. Took a little while to get it off and loose. With that done, I was able to get the rear bearing and doubler onto the torque tube and begin sliding it back. Then ran into an issue with the brushing pre-installed in the toruqe tube. The bearing wouldn't go over the slight protrusion.
