Steve's CH750 Cruzer (N750SB)
Date:  3-27-2017
Number of Hours:  1.00
Brief Description:  Riveted rear SSO support
Removed the gear channel so I could rivet the rear SSO support on the outboard side from the inside so that the rivet tails would not stick out and interfere with the weldement bolts later. Then slipped the gear channel back into place and riveted the channel forward lip to the cabin bottom and rear SSO support bottom. With that done, I think I'm finally ready to join the forward and rear fuselage assemblies.
Pilot Side Rear SSO support
{Passenger rear SSO support
