Steve's CH750 Cruzer (N750SB)
Date:  2-25-2017
Number of Hours:  5.00
Brief Description:  Drilling gear weldements
This was weldement day. Applied masking tape to weldements and extended rivet lines. Drilled #40 holes through weldement and into structure. Removed weldements and upsized holes to 3/16 except for the 2 on each weldement that needed 1/4. Added holes on weldement wings for A5 rivets. Inside cabin, cut and drilled the 2 L angles that attach to the gear channel and cabin side. Incrementally drilled to #20 in the weldement. Drilled the starboard weldement for the seat angle holes. Didn't get to finish the other one today.
Pilot drilling weldement to fuselage
Lots of holes to get the weldement drilled
