Steve's CH750 Cruzer (N750SB)
Date:  2-21-2017
Number of Hours:  1.50
Brief Description:  Finished cabin frame trimming and test fit.
Cut the vertical frame tubes to 85 degrees. With all 4 cuts made, I had several iterations of fine tuning (i.e. filing) before the 4 pre-drilled holes in the frame lined up with the corresponding holes in the fuselage/cabin. Looks like the frame is well positioned for the rest of the mounting holes when I get to drilling those.
Passenger side
Passenger side
Pilot side
Pilot side
Frame fitted to pre-drilled holes
