Brief Description: Reorganize shop, Organize parts
Cleaned up shop and reorganized the work surface for fuselage. Located fuselage parts and grouped parts into rear/front/seat/firewall sets. Ready to start construction. This time the primary work surface will again be the 2 2X12 square beams, but this time I'm setting them on two of the work tables instead of sawhorses. Leftover plywood from worktable construction can be slipped in where needed for additional support. The 3rd table, I will again use for debur/misc operations. Plywood on the sawhorses holds the rear fuselage parts. The wings in their caddy have been rolled back underneath the covered area.
