Taped clear saran wrap to the wing root area on pilot side. Taped fairing into position on pilot side. Used some white Flex-seal glue to taper leading edge of fairing into wing area. Letting it cure before removing. The saran wrap should keep it from sticking to the wing. Hopefully I will get something that can be trimmed nicely.
