Finished up the passenger side wingtip. Had it positioned, but without the lights, so I took it off the plane and attached the lights to the forward section and added a 4 wire computer connector to the wiring on the light and the wire from the wing. Positioned the forward section, connected the wires and added strain relief point. Then positioned the rear section of the wingtip and cleco'd. Tested the connection for the lights from the wingroot and all looked good, so I riveted the wingtip.
