Brief Description: Starboard Fuel system/Root area
Checked for fuel leak after setting overnight. Found leak at connection of the 2 return line segments. Drained fuel to below joint level and disassembled, cleaned joint and re-assembled joint. While the fuel was mostly drained, I worked on fitting the spar root angle, wing root angle, and root nose skin. Since all are replacement parts, I had to be careful to get alignment on the pre-existing holes. Made a cardboard template to lay over the skin to get the holes for the root nose rib. Drilled and disassembled for debur. Refilled the tank with gasoline to check again for leaks overnight.
