Steve's CH750 Cruzer (N750SB)
Date:  10-22-2016
Number of Hours:  2.75
Brief Description:  Riveted Bottom Skin, A5 strut fitting rivet
Finished riveting the bottom skin. I will wait to rivet the pitot/static tube until just before sealing up the top skins so I don't have it sticking out any longer than necessary while I am manipulating the wing. Inserted AN7 bolt into upper strut bracket and fitting to determine location for the A5 rivet that attaches the fitting and doubler. As I mentioned on the left wing, I believe the only purpose of this rivet is to help restrict sliding of the fitting and doubler when the bracket is attached to the fitting under load.
Strut fitting rivet
Strut fitting rivet
Bottom skin riveted
Bottom skin riveted
