Steve's CH750 Cruzer (N750SB)
CH750 Cruzer
Wing - Port
10-9-2016
More wing skeleton work.
Removed rib and drilled fuel return hole. Figured it would be easier to do this now using fly cutter. Cleco'd spar tip and expanded 8 holes for A6 rivets. Drilled L angle for spar tip and positioned. Drilled and positioned 1 flaperon bracket.
Fuel Return Hole Drilled
Ribs cleco'd to main spar
CH750 Cruzer Home
2029
Avionics/Electrical
Cabin
74
220
Doors/Windows
Elevator
225
Firewall
Flaperons
Horizontal Stabilize
Shop Prep
Travel
Vertical Fin
Wing - Port
92
332
332
