Steve's CH750 Cruzer (N750SB)
CH750 Cruzer
Wing - Port
9-15-2016
Tank fitting
Started tank fitting process. Drilled the hole for the fuel return. I'm probably going to use a header tank, so the return will not be used, but I'll install a nipple and cap in case I change my mind.
Fuel return hole
Area of sender
CH750 Cruzer Home
2029
Avionics/Electrical
Cabin
74
220
Doors/Windows
Elevator
225
Firewall
Flaperons
Horizontal Stabilize
Shop Prep
Travel
Vertical Fin
Wing - Port
92
332
332
