Steve's CH750 Cruzer (N750SB)
Date:  9-15-2016
Brief Description:  Tank fitting
Started tank fitting process. Drilled the hole for the fuel return. I'm probably going to use a header tank, so the return will not be used, but I'll install a nipple and cap in case I change my mind.
Fuel return hole
Fuel return hole
Area of sender
Area of sender
