Reassembled bottom skins, doing more deburring and edge prep for each part. Applied Cortec to mating surfaces. Started riveting bottom skins. Also attached strut fitting assembly and bolted in. Torque wrench didn't feel right tightening spar fitting bolts, so unbolted. Sure enough, one of the nuts was stripped and had to be cut off. Discarded the old hardware and retrieved bolts and nuts from port wing. Didn't tighten nuts yet until I get a new torque wrench. Fitting is currently held into place with rivet only. Marked outboard nose skin so I won't forget and rivet until the fitting is properly attached as it is of some degree of importance. I'll need to order new hardware for the port wing. Started riveting bottom skins.
