Steve's CH750 Cruzer (N750SB)
Date:  8-17-2016
Number of Hours:  4.00
Brief Description:  Riveted right ribs to main spar, positioned rear s
Riveted the starboard ribs to main spar. Reinstalled AN3 bolt and torqued to proper spec after looking up AN bolt torque values. Assembled rear spar, disassembled, deburred and applied Cortec. The sawhorse and 2" square pipe made it easy to position and rotate the assembly as needed.
Sawhorses made rotating the assembly easy.
